Rebuilding a welder
发表于 2021-9-1 00:20:19 | 显示全部楼层 |阅读模式
I have a question.   There is a shop here where I live that has some welders that arent' working anymore.  I am wondering where do you find the parts to rebuild a welder and also how difficult and expensive do you think it woould be?  i appreciate any help.Monster“The object of war is not to die for your country but to make the other bastard die for his.”  ~General Patton~
Reply:Not enough info to give a good answer. What brand and model? Import machines are usually throw aways unless you are good at scrounging parts from other sources. Popular name brand models often are easy to find both new and used parts for. Some models it's just not worth spending the money on parts. You can buy a similar working used machine for less than what the repair parts alone would run. All depends on what you are looking at..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I believe its a Miller Deltaweld 302, Im not too sure about the rest of the details.  I know they use the Deltaweld 302.Monster“The object of war is not to die for your country but to make the other bastard die for his.”  ~General Patton~
Reply:you will have to check power input requirements to make sure that you can run them at allDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Originally Posted by monster2011I believe its a Miller Deltaweld 302, Im not too sure about the rest of the details.  I know they use the Deltaweld 302.Monster
GMT+8, 2025-12-22 13:03 , Processed in 0.148161 second(s), 18 queries .
