Leave open or put on a top
发表于 2021-9-1 00:20:17 | 显示全部楼层 |阅读模式
What should I do? Put a top on it or leave it as is?Thanks fellow welders.Redneck Attached ImagesI have not welded in about 18 years, So I need lots of helpHobart Stickmate AC/DC (Present from my wife)
Reply:id put a top on it.. that what stuff wont fall throughM Fed
Reply:depends on what you will be doing with it it could be handy like that if you will be cutting on it, but for welding I would put a top on it or at least on half of it.Yancy,2 Lincoln sticksMiller 210 W/ Spool gun Miller Bobcat 225G Pluscentury 220V Mig
Reply:I will be doing welding on it, I was thinking putting a top on half of it. I was also thinking I shoud be painting it JD Green instead of IH Red.RedneckI have not welded in about 18 years, So I need lots of helpHobart Stickmate AC/DC (Present from my wife)
Reply:the color scheme is all wrong! Attached ImagesYancy,2 Lincoln sticksMiller 210 W/ Spool gun Miller Bobcat 225G Pluscentury 220V Mig
Reply:Originally Posted by yancythe color scheme is all wrong!
Reply:Originally Posted by Redneck5I will be doing welding on it, I was thinking putting a top on half of it. I was also thinking I shoud be painting it JD Green instead of IH Red.Redneck
Reply:Originally Posted by Hammack_Weldingif you want it to work properly then better paint it red.    I make a good living welding JD's back together.
Reply:Put a full top and back splash on it. Hang some of the basics on the back splash. Paint it the old BLM tan so it will set where you saw it last it.
Reply:Paint it green!!! Then you can sell it for twice what you have in it!!!! DanMy instructor said someone will catch on fire during class...He wasn't joking!!
Reply:Originally Posted by Redneck5What should I do? Put a top on it or leave it as is?
Reply:Lincoln Gray or Ford BlueLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:Originally Posted by denrepExcuse me. I stopped in because I thought maybe this thread was about something like convertibles or wardrobe.
Reply:Well you could compromise and paint it Allis-Chalmers orange.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:Use it as in for a while, then add what you need later.
Reply:You guys are making this tough. I also thought about Cat Yellow.I have not welded in about 18 years, So I need lots of helpHobart Stickmate AC/DC (Present from my wife)
Reply:Originally Posted by Redneck5You guys are making this tough. I also thought about Cat Yellow.
Reply:Paint it bright pink, that way nobody will steal it!
Reply:Originally Posted by mb_welderPaint it bright pink, that way nobody will steal it!
Reply:In a much higher voice Come on girls!!  Pink is the new black!! DanMy instructor said someone will catch on fire during class...He wasn't joking!!
Reply:1/2 red, 1/2 greenLincoln AC/DC 225/125
Reply:Red and Green...then you can work on Massys and Deeres
Reply:Redneck, my top is in two halves with a gap about six inches between the halves.I did it like that originally because that's the plate I had, but I now like it because I can clamp things in the middle.I also find that when I'm working on it, the work piece ends up on one half, and the tools, rods etc end up on the other half. The seperation works well.Scott
Reply:ford blueChuckASME Pressure Vessel welder
Reply:Originally Posted by scott brunsdonRedneck, my top is in two halves with a gap about six inches between the halves.I did it like that originally because that's the plate I had, but I now like it because I can clamp things in the middle.I also find that when I'm working on it, the work piece ends up on one half, and the tools, rods etc end up on the other half. The seperation works well.ScottOriginally Posted by chopper5ford blue
Reply:Originally Posted by ca180This keeps coming up, but which shade????There were 3 different OLD ford blues!
Reply:Originally Posted by denrepI can only picture two right now.The lighter, older "Y" block blue, and the darker blue that was on everything for about 25 years.What was the other one?
GMT+8, 2025-12-22 12:51 , Processed in 0.102708 second(s), 18 queries .
