Plow control Bracket...season is over but
发表于 2021-9-1 00:20:14 | 显示全部楼层 |阅读模式
I got a good deal on a curtis plow. 8 footer with everything for 300.00 including the wire harness and controls. I made a wood center console for my F-250 with a panel for switches and such. I do not have a picture of the completed unit, but it is stained and cleared a close color of the interior. I now want to mount the controls so I can rest my elbow on the center console and control the plow with ease. I did this with my other truck and it is great cause there is no reaching for the plow control. So back to the bracket I made for the up/down and left/right swtiches along with the light switch. The bracket will attach to the end of the center console box where my hand is at rest. I had to mill a slot so the switch body will fit. I also turned up some spacers. I tigged the spacers on so I could counter bore them for socket head cap screws. I have not mounted it yet but I will soon.T.J. This was a fun job.....material 3/16 thick bracket, bushing wall--don't know who caresDyn 300DX. Argon 13 CFHTungsten 3/32 Amps 195Balance 70Freq. 150Hzfiller 3/32 5356 www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
GMT+8, 2025-12-22 12:53 , Processed in 0.095492 second(s), 18 queries .
