pipe bender plans
发表于 2021-9-1 00:20:14 | 显示全部楼层 |阅读模式
hi im 14 and live in australia and im goin to make a pipe bender.i need to know a few things first though. where could i buy some dies for it.i live on a farm so i got a lot amd scrap metal that in going to use.a picture of a simple idea i got i was goin to upload a picture but cant seem to get one on ill try again later
Reply:i ve found how to resize the picture now so ill put it up
Reply:im basing it on one like this http://cgi.ebay.com.au/HYDRAULIC-PIP...QQcmdZViewItem
Reply:http://www.gottrikes.com/Tube_Bender.htmTONS of people have built this bender with nothing but good luck.  The plans are very easy to understand and well worth the money.  He also tells you where to buy all the parts, including jacks, dies, shafts, bearings etc...
Reply:Originally Posted by drivethruboy54http://www.gottrikes.com/Tube_Bender.htmTONS of people have built this bender with nothing but good luck.  The plans are very easy to understand and well worth the money.  He also tells you where to buy all the parts, including jacks, dies, shafts, bearings etc...
Reply:I was going to have a crack at this one too but with our upcoming move to australia I'll probably just sit on the plans and watch this thread for now
Reply:I have to agree with drivethruboy54.  Plus Frank seems like a great guy. I have cut and drilled all the steal but just have not welded mine up yet.
Reply:I hate to take poop on a project, but these benders are fairly cheap at northen or h/f. I have one and was let down by it.  it's very hard to get 2 bents on one pipe. I found that sch 40 pipe is about the best the work with. other pipe seem to kink.  Anyway here's a pic, and if you need some dimensions let me know I be happy to help you out. just my .009/10 cents    Daye Attached ImagesLast edited by tigmusky; 03-25-2008 at 07:26 PM.
Reply:Took a look at the gottrikes version.  Where's the best place to dies for something like this?TIA
Reply:Protool seems to be the place for dies.
Reply:protoolseverything you need to build is on a parts list with manufacturer name
Reply:I just ordered the plans from Gottrikes, they are well worth the money.  The plans explain everything from start to finish!!  They even have alot of pics for those of us who hate to read instructions.MolongneckLincoln 175HD MigWard's Powr-Kraft 230 ARCHypertherm Powermax 45Harris O/A TorchMakita 2414NB Chop SawMakita 9557PB 4 1/2" Angle GrinderClarke BT 1002 6" Brench GrinderRyobi DP 120 12" Drill Press
Reply:you were right those are cheap pipe benders not tubing benders. there is a huge difference in workmanship and price! jus my 2 cents worth greg
Reply:thanks for your inputs, and ive heard that those pipe benders arent to good. so i was wondering if any one knows where i can pick up some FREE plans for a good pipe bender and tube bender
Reply:brother, spend the 17 dollars or whatever it is in got trikes plans, its well worth the money
Reply:Go trikes Plans are very easy. They use ProTools Dies and I can tell you the Guys at ProTools are 1st Class.I've nearly finished my bender, as soon as I can I post some pics up.
Reply:Here is a link to the thread that covers my build of Franks Tubing bender. http://weldingweb.com/vbb/showthread.php...nally+finished
Reply:I built mine last summer, definitely worth the cost of the plans.  I built mine with the air/Hydraulic cylinder, spend the extra 20-30 bucks for it, it makes a night and day difference. It seemed to be about 60 pumps per 90 degree bend manually, vs. press a lever and wait. He has plans to use the air/hydr. unit now, but when I did it, I just modified the original plans to take into account the larger cylinder base.PatrickLincoln 175HD
Reply:Ok, do you want a PIPE bender or a TUBE bender?  They are different.  If you only need to bend PIPE the Harbor Freight style is the cheapest route.  If you want to bend TUBE or PIPE you can go with the ProTools, JD2 or gottrikes version.  With the second options you can buy dies for either pipe or tubing but far as I know no one die will do both pipe and tube because of diameter differences.The bender you have sketched is like what tigmusky posted and is for PIPE not TUBING.  They will crush/stretch tubing.
Reply:Originally Posted by PatrickJI built mine last summer, definitely worth the cost of the plans.  I built mine with the air/Hydraulic cylinder, spend the extra 20-30 bucks for it, it makes a night and day difference. It seemed to be about 60 pumps per 90 degree bend manually, vs. press a lever and wait. He has plans to use the air/hydr. unit now, but when I did it, I just modified the original plans to take into account the larger cylinder base.
Reply:this is a good placehttp://blindchickenracing.com/Tools/...bingbender.htm
Reply:That is the GotTrikes bender mentioned above.http://www.gottrikes.com/Patrick Originally Posted by bhardy501Where did the plans for this bender come from? I would like to build one like it.
Reply:Anyone have plans for a bender that can do 30mm (1.18") solid round bar? Gottrikes said his wont do anything that thick
GMT+8, 2025-12-22 12:48 , Processed in 0.604655 second(s), 18 queries .
