Snow Plow for Lawn Tractor
发表于 2021-9-1 00:20:09 | 显示全部楼层 |阅读模式
Well I have this craftsman 12hp I modified and I want to put a plow onto it.I just bought a mig welder and thought it would be a good project.and a good way to get experience.Does anyone have plans?
Reply:Have you searched this site?  You'll find countless posts regarding blade-building.Lincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:Originally Posted by AquafireHave you searched this site?  You'll find countless posts regarding blade-building.
Reply:heres one i found from a member herehttp://www.mytractorforum.com/showthread.php?t=67335you can either find a metal cylinder, cut in half. or check ebay for them and mod it if needed. the older stuff is better builti found one that was designed for my 72 ac 712 and it was only 125 shipped, heavy too http://cgi.ebay.com/SEARS-SUBURBAN-T...item2560f5abc9i
GMT+8, 2025-12-22 13:04 , Processed in 0.093387 second(s), 18 queries .
