storm door
发表于 2021-9-1 00:20:07 | 显示全部楼层 |阅读模式
should've took pics during the buildDewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Looks great!  That should withstand any storm!A fellow I commute with is involved with the local Little League.  He said they have been having problems with the snack shacks getting burglarized by punks stealing soda pop and candy bars in the middle of the night.  I will use your storm door as inspiration to cure their problem.-MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Some specifics:  1.5 sq. tube and 1.5 x 3 x 3/16" rec tube for the frame.  10ga sheet on the outside and 16ga inside resting on 4 heavy duty ball bearing barrel hinges with grease fittings.  I would've posted more pics but I didn't wanna go through resizing them all.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:We had the same problem here with our snack shacks. It really is a bummer for the kids.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:SWEEEEEEEETTTT now that's a door. Do you have any pics from the inside?Does that go underground any? It's not what you can buy, it's what you can build that matters
Reply:Is that a bunker door?Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:Squatters also have similar problems. Our solution after the whole doorframe got pulled out was to weld 2" angle up into a doorframe then use 1" reinforcing rod as "bolts" to attach it to the building. Welded both sides  The door itself was a steel frame with reinforcing and lots of plywood and glass (makes it tricky to cut through with a grinder). Eventually they used a bulldozer to make opening the door unnecessary.http://moz.net.nz/photo/2002/10-stardoor/
Reply:Originally Posted by hytekredneckSWEEEEEEEETTTT now that's a door. Do you have any pics from the inside?Does that go underground any?
Reply:ouch... would want to be stuck behind one of these storm door... great door notheless... only if we can see the back of the doorUnit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
GMT+8, 2025-12-22 14:01 , Processed in 0.120351 second(s), 18 queries .
