Ahhh The Good'ol Dayzzzzzzeeee...
发表于 2021-9-1 00:20:05 | 显示全部楼层 |阅读模式
Seeing as I have no argon left its time once again for "Stick Welding With 7018"...Still building up machine chucks..Looks like cake frosting don't it? And to answer the question before it happens..Yes..It takes longer to stick weld these than to Tig them.. I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Sorry Zap but I like your tig welding much better That one of the fun jobs I am glad to let you have Hope the argon get there fast.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Mmm-mmm-mmm. What J. Little said!!  It would be interesting to see how well it cleans up!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by tanglediverMmm-mmm-mmm. What J. Little said!!  It would be interesting to see how well it cleans up!
Reply:Good to see you are actually human.Lots of toys.
Reply:It's good to get out of your comfort zone every once in a while... It keeps you sharp.
Reply:Your stick welds look a little like tig.  I run beads the opposite way each time, then the cold start is over the crater from the last weld and visa versa.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Guess I have it a little better, the metal supplier we buy our gas from is less than 1 mile round trip../good luck, waiting to see more postsI wonder if I will be spanked for this one too!?!
Reply:I thought you only like tig... well I was wrong then... good job... when you goin to mill it?Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:Originally Posted by westlawn5554xwhen you goin to mill it?
Reply:I used to do a lot of that using gmaw. We had an old lathe chuck rigged for a roller with adjustable speed. Start at the back and run one continuous bead all the way out. Brush it off and do another. It went pretty quick but was thoroughly boring. I finished a build up job on some track hoe teeth yesterday using 309L (customer specified it even though I recommended a hard surface rod). Took 4 hours to do 4 teeth then another 4 shaping them with a grinder. You should have heard him squeal when I handed him the bill.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:Originally Posted by Jolly RogerYou should have heard him squeal when I handed him the bill.
Reply:Originally Posted by Jolly RogerI used to do a lot of that using gmaw. We had an old lathe chuck rigged for a roller with adjustable speed. Start at the back and run one continuous bead all the way out. Brush it off and do another. It went pretty quick but was thoroughly boring. I finished a build up job on some track hoe teeth yesterday using 309L (customer specified it even though I recommended a hard surface rod). Took 4 hours to do 4 teeth then another 4 shaping them with a grinder. You should have heard him squeal when I handed him the bill.
GMT+8, 2025-12-22 14:03 , Processed in 0.087991 second(s), 18 queries .
