Lincoln Invertec v205-T AC/DC tig welder
发表于 2021-9-1 00:20:03 | 显示全部楼层 |阅读模式
how is everyone doing. Iam wondering why I can't come across anyone who has had the experiance of using the lincoln v205 AC/DC tig welder? maybe this tig is to new or no good? any info would be great.
Reply:They had one used in a welding shop in Charleston SC where I haunted. The welders liked it. It's about the same price if not more than a Dynasty 200DX plus made overseas. Why even consider this welder unless you like the color red???Millermatic 210Dynasty 200DX Fisher CZ-5Trek 5500
Reply:thanks for the reply wheat.thats what I was afraid of ,something imported.I originally was set on getting the dynasty 200dx but my local welding supply store told me I could only get the full 200amps out of the machine if I was running on 3 phase. in my shop now, Iam running single phase 230volt,at that power set up I was told I would only get 150amp max from the dynasty.I also was told that with the lincoln v205 on single phase at 230volt I would get the full 200amps from the machine. thats why I was undecided.
Reply:I have one for the last 2 years, I am very pleased with it. It has the lincoln warranty ,and I do not care if it is made in Italy, this machine is great.On single phase you get the full 200 amp on dc at 32 amp draw, if you run on AC, there is a small restriction, above 80 cycles up to 150 you are limited at 170 amp. This has not bother me so far.I have done stick with it and it has a great performance.This unit in my shop is used for tig dc and ac.I would not hesitate to by one great machine..Have fun Michel
Reply:Originally Posted by WheatThey had one used in a welding shop in Charleston SC where I haunted. The welders liked it. It's about the same price if not more than a Dynasty 200DX plus made overseas. Why even consider this welder unless you like the color red???
Reply:I would pick the lincoln before i would pick the miller.  Matter of fact, i would buy the lincoln before i would let someone give me the miller.  It runs off of less power for the total amp output, is more user friendly, and the quality is there no matter where it is made.A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:The red one pick the red one.   I got the v200t- no ac on it, she's 5 years old and has had a hell of a hard life. She's at the shop getting the HF looked at but I don't mind because she's done that much work (on 3 phase) that it's time to put her into retirement soon. It would be interesting to know how many tonne of rod's she's burned Stephen
GMT+8, 2025-12-22 14:01 , Processed in 0.091772 second(s), 18 queries .
