Questions on ESAB welder setup
发表于 2021-9-1 00:20:02 | 显示全部楼层 |阅读模式
I recently purchased an ESAB Mig/Tig/Arc welder.  Both my son & I have had difficulty getting the rod (E6010) to strike.  We set the voltage as recommended for welding on .1875 steel tubing.  I was wondering if the rod might be bad or if we just don't have the machine set up properly?
Reply:If its a 360 you have to make sure the function switch is set on stick.  Won't work if its set on mig or tig.
GMT+8, 2025-12-22 15:29 , Processed in 0.102022 second(s), 18 queries .
