Good source for plans?
发表于 2021-9-1 00:19:57 | 显示全部楼层 |阅读模式
Folks, I am looking to build a dump bed for a tandem truck sometime this spring or summer.  I would like to have it up and operational by fall to haul corn and soybeans on.  I have looked into buying a bed, but that was about $15k for a 20' bed.  I could copy a bed I like, or just do as I normally do and figure it out myself, but I would really like to find a good blueprint I could buy with materials lists etc.  Does anyone know of a good source for plans and blueprints for truck beds, trailers, etc?
Reply:Lincoln publishes or at least used to publish several books of welding projects, mostly for stuff around the farm.  There were lots of projects for trailers and the books were very inexpensive."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:What have you built in the past?  Where did you get your plans?Also are you planning on all new materials or do you have a source for scrounged materials? When you build something from old parts, scrap, cast offs, or "good junk"; your design will by necessity reflect the parts you have at the time you do the work.An example would be the trailer body I saw that was made from an old boiler shell.Good Hunting, on finding plans with the bill of of materials to build a tandem dump trailerI doubt you will find someone to do the R&D and then almost give away their plans.. The figuring out how to do something for the first time is usually much more difficult than just putting something together.
Reply:http://trailer-bodybuilders.com/ might be able to help you outCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Here ya behttp://www.northerntool.com/shop/too...atchallpartialOoops, he said truck bed, but the trlr plans ought to be of some help?Last edited by farmersamm; 02-04-2011 at 12:22 PM.Reason: FTR........failure to read :)"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I don't have any plans, but some of our older truck bodies on our farm are simply 2x? box tubing or c-channel main rails (hinged at the rear). Then C-channel cross rails 8 - 8 1/2 feet long at 90º to the main rails and on top of them. Cover with plate of an appropriate thickness. The sides and ends are supported by uprights welded (or bolted if they are to be removeable) to the c-channel. Newer style truck bodies are a little harder to do in the home shop, as they seem to be going to plate formed into special rails, etc. for cleaner look, lighter (more payload), etc.Andrew
Reply:Try this one http://www.dumpbeds.com"Easily convert your regular pickup truck, utility trailer, farm trailer, or whatever into a fully-functional, versatile, and reliable - high capacity professional strength dump truck or trailer.The uses are absolutely unlimited... For all of you do-it-yourselfers, backyard mechanics, gear heads, professional fabricators, and just plain-old cheapskates alike, this is the perfect project for you!With these plans, the necessary parts/supplies, the appropriate tools and skills, and a little bit of time and money – you’ll be on your way to success in no time."Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
GMT+8, 2025-12-22 14:03 , Processed in 0.301607 second(s), 18 queries .
