End caps
发表于 2021-9-1 00:19:57 | 显示全部楼层 |阅读模式
What is the best way to cut and weld  end caps on square and or round tubing and pipe.
Reply:These always look cool.  Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Cut bend and weld...... now I can beat it flat
Reply:I looked locally for plastic caps and could not find them. I searched the net and found a few places but with shipping charges it was not worth it.I just cut a piece of flat stock to cover the hole and weld it in place.i like  Thats Hot idea.Dave ReberWadsworth Ohio
Reply:really depends on the application but here is a good place to lookhttp://www.wagnercompanies.com/end_caps.aspxLincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:Or make life easy for yourself and purchase a set of end caps? bevel the end of the pipe and set it up like a pressure weld.
Reply:Thanks for all the info.
Reply:Cut a piece of flat stock so it is just a bit smaller than the end of the tubing, tack in place and weld it vertical down, rotating as u go, if its just for looks.Nothing Ever Got Done By Quitting, Never Give Up.
Reply:Originally Posted by CEPThese always look cool.
Reply:Originally Posted by tigmuskyinteresting..  can you share more??Daye
Reply:Thanks, cep   I'll have to give it a try, maybe make a jig for the plasma cutter.Anything in that book on, makeing a taper on a pipe?  like a cannon? Thanks DayePound to fit, paint to match
Reply:Originally Posted by tigmuskyThanks, cep   I'll have to give it a try, maybe make a jig for the plasma cutter.Anything in that book on, makeing a taper on a pipe?  like a cannon? Thanks Daye
Reply:Originally Posted by CEPYes there is, concentric reducer, and eccentric reducer, two-cut eccentric reducer. About 10 pages total!Maybe tomorrow I'll scan the concentric reducer pages if you want them. But right now I have to take off.
Reply:Here's that info. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:oh the fun you can have.....anytime i attempt any of the stuff in franklands book it reaffirms my respect for the old time pipefitters...second foto shows in detail how to really phoque it up....then you get to fix it..once you've heatandbeat the leaves in too far you cant just get them back out to make it all round and smooth..... Attached Images
Reply:Yup, steam and old skool pipe fitters had it going on.  I wondered how they did it back in the day and now I see.  Lots of skill went into that stuff  along with the knowledge and expertise.  Thanks for the info.BobI'm spending my Kids inheritance, I dont like him that much anyway!!!!!!Enuff tools to do the job, enough sense to use em.Anybody got a spare set of kidneys?  Trade?
Reply:lol again, purchasing nicely machined end caps which every local pipe fitting store has or can order made for pipe would have looked much cleaner, better fitup, less work, and much much easier to weld.
Reply:Originally Posted by Pressure_Welderlol again, purchasing nicely machined end caps which every local pipe fitting store has or can order made for pipe would have looked much cleaner, better fitup, less work, and much much easier to weld.
Reply:If I tried this, I think I'd see a lot of scrap in my future "Any day above ground is a good day"http://www.farmersamm.com/
Reply:Long time lurker coming out of hiding...Took a while of digging through my downloads, but found this version of the orange peel chart I d/l'd several years back, with a bending jig at the bottom. Would be a handy jig (or set) if you need to do many of the same size(s).Mike "Dodis"Century 135 MIGMiller Thunderbolt XL AC (working on DC converter) (SCORE! got a H/F box off eBay for this one too) now gotta get busy!!! Harbor Freight 130 TIGOxy/Propane Victor Torch
GMT+8, 2025-12-22 14:00 , Processed in 0.121405 second(s), 18 queries .
