welding Inconel...
发表于 2021-9-1 00:19:55 | 显示全部楼层 |阅读模式
well as a the topic states, has anyone here ever welded Inconel? the reason is i'm in the final semister of welding school. i'm welding stainless steel pipes and i'm not having a problem; it's not as bad as i thought. so friend of mine graduated last semister while he did some small jobs welding stainless. then came across this company that welds Inconel locally. this company only hires twice a year, yet he tested, passed and now he is hired. i receieved this call from him earlier today asking me if i would consider coming down on august to test, which will be the 2nd time they will start hiring again this year.so please any advice on what i need to do from preping, welding, gas sheild, etc. please do help. he stated i shouldn't have a problem but never the less i like to be prepare. he did tell me one thing tho, since i practice welding 2" Sch 120 pipe i should not have a problem due to how i understood the process of tig'in it and passing a weld bend. so again please any help will duely be appericated.remo.it's trust and character I need around me. You know, who you choose to be around you lets you know who you are. One car in exchange for knowing what a man's made of? That's a price I can live with. - Hans
Reply:Inconel is not that much different than stainless. If you are proficient with stainless you should have no problem with it. Shielding gas is Argon just like stainless. I have taken many tube tests on inconel, and you set it up and run it the same as stainless. Be sure to purge, and remember it is a little more runny than stainless.
Reply:thank you thats a start, i was told the samething.it's trust and character I need around me. You know, who you choose to be around you lets you know who you are. One car in exchange for knowing what a man's made of? That's a price I can live with. - Hans
Reply:What's filler rod cost? $100 / lbs?Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:Originally Posted by con_fuse9What's filler rod cost? $100 / lbs?
Reply:It also welds at a lower amperage than stainless. Keep it cool.UA Local 598
Reply:thank you guy any help is better than going into the booth to test blind.it's trust and character I need around me. You know, who you choose to be around you lets you know who you are. One car in exchange for knowing what a man's made of? That's a price I can live with. - Hans
Reply:Welds real similiar to stainless steel. I disagree about less heat though.
Reply:Also, sometimes the Haynes alloys (Hastalloy) are called Inconel.  C276 is the most common culprit for this naming SNAFU.  Inconel is really a generic term anymore for the ASME P Number 43,44, and 45 materials.
GMT+8, 2025-12-22 13:54 , Processed in 0.096504 second(s), 18 queries .
