tig with no gas
发表于 2021-9-1 00:19:52 | 显示全部楼层 |阅读模式
can you weld mild steel with out gas with a tig, just to get used to the puddle and not use up the gas??? thanks.
Reply:hi caosesvida.  no.  you have to use the gas. (argon)jake
Reply:tungston inert gas .......T.I.Gbonez
Reply:You can not do it because it oxidizes the tungsten.
Reply:Heres what you do..........unscrew the lines from the rig.....and sleep with it...get a piece of 2x4 pine and start walking the cup on it....you will see the marks left from cup on the wood.......this is what the bead will look like when you start to put filler metal in the pass. No gas needed for practice....
Reply:how much pine did you walk mikey? i feel like i've been through the forrest lololol  i don't have a spunky username just what it is, me!
Reply:12"  and it was in the car driving, on the table, under the table, over head, behind my back....and that was a long time ago....
Reply:thanks, I didn't know that the tungsten needed the argon to survive, I thought it was for the oxidizing the weld.
Reply:I you like to buy tungstens, try it! At some point you probably will forget to turn on the gas and the tungsten will go puff! Take care.
Reply:Hi All,  I can't believe I'm talking welding when I'm not at work  Anyway Robin, any young fella's that I teach I try to get them going free-hand first, that way when there in a real tight spot they at least know how to do it. It's a lot easier to learn to walk the cup later.Well it's a theory anyway.Cheers
Reply:Like I said, I'm not taking anything from the free hand guy's or all the gloves they have to buy........ But when you master walking..... you can put the metal anywhere you need it......
Reply:without the gas it's just like stick welding
Reply:Originally Posted by guy-finniganwithout the gas it's just like stick welding
Reply:well ya thatz wut i meant.. sorry for not explaining that
GMT+8, 2025-12-22 14:23 , Processed in 0.090876 second(s), 18 queries .
