finished my table...
发表于 2021-9-1 00:19:50 | 显示全部楼层 |阅读模式
Well the finished product came out ok. I think design will be strong enough at least for normal use. Large people maybe should not attempt to tear off a piece though size of the top may be a natural limiting factor. Then again if I can find a babe hot enough to give it a try....Airco 300 squarewaveMig welding center...Powcon sm300/LN 25Powcon sm200/PD lHypertherm PM 1100Miller AEAD 200LE W/LN25 FCand now another sm200 pd l combo.
Reply:Looks good man, do you have an underside shot and how it is attached???Come try it out and stay a while.
Reply:Not of the finished piece but the top is attached with a tab at each corner of the frame and tnuts set into the top. Used a 3/8" stainless bolt through the tab and into the tnut. Top is 3/4 birch ply and the 3/8 tnuts fit well and should be strong enough to lift the table from the top.Here is previous pic of frame before paint....Airco 300 squarewaveMig welding center...Powcon sm300/LN 25Powcon sm200/PD lHypertherm PM 1100Miller AEAD 200LE W/LN25 FCand now another sm200 pd l combo.
Reply:PS, it is not very heavy maybe 50lbs max.Airco 300 squarewaveMig welding center...Powcon sm300/LN 25Powcon sm200/PD lHypertherm PM 1100Miller AEAD 200LE W/LN25 FCand now another sm200 pd l combo.
Reply:Nice job I really like the base design and the wood and iron work good together. Well done!If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:Thanks, I thought about granite, would look great but I wanted to be able to move it without calling the neighbors....Airco 300 squarewaveMig welding center...Powcon sm300/LN 25Powcon sm200/PD lHypertherm PM 1100Miller AEAD 200LE W/LN25 FCand now another sm200 pd l combo.
Reply:If you want to see some other types of table legs look on the garden bench thread. I just posted a couple of the tables I`ve built for people.
Reply:Looks good bro, I like original stuff in a house, really sets it apart
GMT+8, 2025-12-22 14:27 , Processed in 0.089124 second(s), 18 queries .
