Stainless Steel Work
发表于 2021-9-1 00:19:48 | 显示全部楼层 |阅读模式
I just thought I would share a picture with you.  This item are part of a MASSIVE spiral freezer job getting ready to be installed.  I will add more pictures later.This picture utilized the Tig process...fused no filler.  (Stainless steel)  Everything has been galvanized.Very time consuming job.  There were severla hundred washers to each beam.  I was lucky enough to be the one to weld all of them... Attached ImagesBeauty in the Bead!
Reply:Nice work, I do alot of stainless where I work.  It can be tricky at times.
Reply:You say, it's been galvanised. I've never heard of S/Steel or any other metal other than Steel been treated with Zinc, why was this process used.Nice welds by the way.
Reply:Nice looking job but I bet it got tiresome. I am curious about why stainless needed to be galvanized too.
Reply:I see that bead number 32 on the far right washer appears to be .005" larger in dia. than bead number 31, how will this affect the outcome of the upcoming general election? (For extra credit, show your math.) That's a bunch of washers, nice job! City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by ASODThis picture utilized the Tig process...fused no filler.  (Stainless steel)  Everything has been galvanized.
GMT+8, 2025-12-22 14:27 , Processed in 0.076864 second(s), 19 queries .
