Removing a bearing race
发表于 2021-9-1 00:19:48 | 显示全部楼层 |阅读模式
I needed this spindle for a trailer.  Its been around for a while, so I got new bearings.When the bearings cooled, they almost fell out.Pulsed spray mig, .035 wire 350 ipm, AG8.Anything....Stick, Mig,........DavidEdit,  Yeah, I welded over the rust!Last edited by David R; 04-22-2008 at 08:58 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Neat! I read about doing that but never seen it done. I guess it goes with out saying that you have to becareful to only weld on the race.
Reply:I haven't welded a race to the hub yet.....Been doin  it for years.  David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Great trick David. Too bad I couldn't have used that to remove the unit bearing from my AAM 925 on the dually last weekend!Patriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:on real delicate or tight spots you can just run a bead around with the tig welder adding no filler . you dont even have to go the full 360insert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:Cool!The TIG sounds a bit safer, and no spatter to clean off.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:HAH!   That's a hoot, but wow, those were sure rusty! Here we are always using a big taper punch and hammer!David, did you have your hernia procedure yet? I've lived with a hernia since high school, three years ago...or so.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:You can also drop in the new ones by cooling them with co2 from an inverted cylinder.They expand quickly though; so if a large cup bounces (shut up!) when dropped in, it can expand out of place and be a pain to seat home.
Reply:Originally Posted by denrepYou can also drop in the new ones by cooling them with co2 from an inverted cylinder.They expand quickly though; so if a large cup bounces (shut up!) when dropped in, it can expand out of place and be a pain to seat home.
Reply:Never thought of that! Just passed on a bunch of spary cans of Super cold (nitrogen?) used to cool electrical boards for soldering. That would have been a good use.
Reply:Put them in the freezer over night works too.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:All good tricks of the trade !  John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Propane works to chill races and quickly. Use a short hose and turn the tank upside down to get liquid. Doesn't take but a minute. Always do this outside and it helps if you have a little wind to disperse the gas. No problem here as the wind is always blowing. It is a way to do it on the jobsite. Around the house I just put them in the freezer for a hour or two.
Reply:I used to use this TIG trick to remove valve seats in aluminum cylinder heads.  You don't really have to go all of the way around to drop them out of aluminum.  The interference fit is about .007" so they are much harder to put in.  I put them back in with a pneumatic chisel gun setup with a custom made bearing seat and pilot turned to the valve guide size.  Then I put the seats on dry ice for a few minutes to shrink them.  I heat the head under a soft brush torch or better yet, in an oven to melt a 400* tempstick.  Use gloves to mount the cold seat on mandrel and carefully slide the pilot in the guide, pointing in the upward position so you don't drop the seat, but place it.  Align in the seat to the pocket and ZAP, it's in.After the head completely cools to room temp, use a .002" feeler gauge and check under it to ensure it seated properly.Hobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:done that lot of times with a stick welder fixing rock crushersChuckASME Pressure Vessel welder
Reply:We would that to cylinder heads like rick said, but we also would do that with aluminum blocks to get the sleeves out somewhat easier, they were getting smashed for scrap and the sleeves were always a pain.Yup
Reply:Very cool trick Dave. I never thought or even seen that done. I know I will use it soon as I run into this quite often.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:thats one of those  "damn, could have used that 2 weeks ago"  sort of thingsnice trick!
Reply:Thats about one of the neatest tricks I've seen lately. Will definately add that to my little bag of tricks. Thanks DavidG3miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:I was very impressed the first time I saw that done.It's one of those  "DUH!"  Why didn't I think of that? tricks.Good post David. I'm sure lots of guys will be makin' their lives easier next time.
Reply:Seems I never get those like that. I always get the ones on the shafts, lol.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:Jolly Roger-  Just cut those across the race in one place with a carbide disk and die grinder as thin as possible and finish it with a hammer and chisel.  It'll pop right off once the stress is relieved.Hobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:Jolly roger, the ones on the outside of the shaft, I heat till glowing red and hit em with the peen end of he hammer.  They expand and fall right off.  I trashed too many shafts using a torch.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:David, I cut them off shafts with a torch. There is a little trick to it but you will not damage the shaft. I usually cut both sides and they just fall off. If I could post a picture I would show you how I do it and I gurantee you won't hurt the shaft.  Jolly Roger was just joking. He knows how to do it.
Reply:If you cut them off a shaft when the shaft is still hot, you will cut into the shaft, but if you wait untill it is cold, and just preheat the race and cut it, there is less chance of wrecking the shaft.Nothing Ever Got Done By Quitting, Never Give Up.
GMT+8, 2025-12-22 15:54 , Processed in 0.096273 second(s), 18 queries .
