Tig Cup Sizes
发表于 2021-9-1 00:19:46 | 显示全部楼层 |阅读模式
Does anyone know the range of current for each gas cup size.. like a number 8 cup (half inch) should be switched to a 9 when the amperage is passed how many amps.. and how low should the amperage be before you switch it to a 7? If you get what i'm saying then could you please make a list of the amp range for each cup size.. it would be greatly appreciated.. thank you!
Reply:someone has to know or have a chart or something
Reply:I don't worry about amps for cup sizes unless it's alloy at hot amps, for carbon and s/s it has no effect (under 170 amps). The cup sizes are more for different preferences (and at times weather conditions). If that makes sense.Stephen
GMT+8, 2025-12-22 14:28 , Processed in 0.069519 second(s), 18 queries .
