查看: 13|回复: 0
MIG Tubular Steel
发表于 2021-9-1 00:19:46 | 显示全部楼层 |阅读模式
As a newbie have enjoyed and learned so much from this forum.Thanks. My question is suggested settings (gas, speed etc) for welding a tubular steel fence using 1x1' rails 1/16 inch thick to 5/8" verticals. Have a Miller 210 and using .023 wire. The bead is so short between the start and end that I can't get a smooth run. Does a speed of 30, setting of 2 and 15 cu ft sound right?
GMT+8, 2025-12-22 15:54 , Processed in 0.086224 second(s), 18 queries .
