Lincoln v-160s not working
发表于 2021-9-1 00:19:42 | 显示全部楼层 |阅读模式
Their is a unit that isn't working claims it fires up andFan runs but it won't weld would this unit be worth buying and fixing for 350?
Reply:Hey smile,found this http://www.lincolnelectric.com/asset...OLN3/im737.pdf it might help you figure out the problem. Also I don't think anything is worth money if it's broken, unless you know exactly what the problem is.good luckRemyhttp://lineboring.org
GMT+8, 2025-12-22 15:52 , Processed in 0.094521 second(s), 18 queries .
