miller econo twin
发表于 2021-9-1 00:19:42 | 显示全部楼层 |阅读模式
Looking for information on the miller econo twin without hf. Just bought it today thinking I could use it to learn to tig weld.  It has the torch with gas control valve. Any  advice or information would be a big help   Thanks
Reply:Not to send you packing, but the guys on the Miller board may be able to elaborate on that machine. I have only seen them listed on the owners' manual section. Type in your serial number and/or the exact model and you can get the entire Owners Manual in pdf form.Or use this link.  ---> http://www.millerwelds.com/om/o302j_mil.pdfCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I downloaded the manual but it only talks about the hf for doing tig welding.  I guess my question is will the machine I have tig weld or do I have just a stick welder .  Thanks for your help
Reply:it will tig dc only
Reply:If this welder will tig weld how do i set up the the welder.  I have the argon and the torch handle but ther is no lead off the torch to plug into the welder just the hose that goes to the regulator with a brass looking block that the hoses are attached     thanks for any helpLast edited by bustoh; 02-09-2011 at 08:21 PM.
Reply:Picts of what you have would help. I'm guessing you have a set up similar to Tozzi's scratch start tig rig shown here.http://weldingweb.com/vbb/showthread.php?t=38106.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:That is exactly the set up I have. I will hook it up tonight and see what happens. Thanks for the help
GMT+8, 2025-12-22 14:26 , Processed in 0.068083 second(s), 18 queries .
