Hi , i am a beginner welder from Egypt so ,i need to some free lessons about carbon welding "flux core welding" .i work as a welder to built ships in shipyards thus , my work is welding a different stiffeners as ( bulbs , brackets , plates , Pillars and etc ).i will be so happy with your helps.
Reply:Welcome to the website, I wish your country success in becoming a democracy, hopefully peacefully from this point forward. Your freedom makes the world a better place for all. As far as learning about welding, I think you should try and read many of the old posts on this site. You can learn so much about welding this way, most of your questions have been asked and answered before, possibly many times and in various different ways. Once you have done that, ask specific questions here about what ever you need help with and members will be glad to assist you.Good luck!"The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25 |
