What are the characteristics of inverter welding machine?
管理员
Rank: 9Rank: 9Rank: 9
发表于 2021-6-10 16:50:23 | 显示全部楼层 |阅读模式
① The welding current is close to complete direct current, the thermal efficiency is high, the welding current of the same workpiece can be reduced by 40%, the welding range can be increased, the electrode life can be improved, and the energy saving effect is obvious.
② The weight and volume of the resistance welding transformer are reduced to 1 / 5-1 / 3 of the same power frequency welding machine, which improves the flexibility of the welding machine.
③ It can improve the control accuracy and response speed, and it is easy to achieve stable constant current control.
④ The control is more reliable. In case of fault, such as short circuit or grounding, IGBT switch is cut off within 3 hours, which is much faster than thyristor.
⑤ Because the secondary circuit is high-quality DC, no inductive loss, improve the effect of energy saving
GMT+8, 2025-12-18 10:24 , Processed in 0.071134 second(s), 18 queries .
