Try not to be TO critical.
发表于 2021-9-1 00:19:33 | 显示全部楼层 |阅读模式
This is my first project. Im pretty satisfied with it myself. It was a stand up grill and I made it into a laydown smoker. As said by CHENRY:you cant weld on a thingamajig like that. are you even certified to do thingamajig welding ? I once saw an improperly welded thingamajig fail and eleventy twelvoteen things got ballywhacked. I dont think i would risk it.
Reply:I'd be much more impressed (jealous) if I saw it with some food in it!!  some things I just can't live without.
Reply:Originally Posted by EngloidI'd be much more impressed (jealous) if I saw it with some food in it!!  some things I just can't live without.
Reply:Good job, I'd be proud too.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:I like it.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:looks goodChuckASME Pressure Vessel welder
Reply:Just one suggestion: Finish up the lower shelf and cover that exposed Expanded edge- that will slice and dice anything that brushes against it.
Reply:add beer and bar-b-que, and you are cooking...literally!!!Looks good from here.  A bbq is a good project to start with.  You might want to put a frame around your grill top, to prevent bending and warping...that's about the only thing I would do extra...but, only after the beer and bbq.Smithboy...if it ain't broke, you ain't tryin'.
Reply:Some paint, Few beers and some fresh roadkill, be just right. gitr done
GMT+8, 2025-12-22 14:19 , Processed in 0.194634 second(s), 18 queries .
