Busted Tranny mount i did a while ago.
发表于 2021-9-1 00:19:31 | 显示全部楼层 |阅读模式
Culprit is cast aluminum tranny off a ford tractor. Cleaning was carb cleaner rag and wire brush. 4043 filler Miller Areowave set at 300A Attached Images --Gol'
Reply:How do you hold an oddball shape like that in place while you weld it?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11How do you hold an oddball shape like that in place while you weld it?
Reply:you would be suprised what you can do with an assortment of blocks.I have a 2x5x6 aluminum block and 2 pieces of 2x4 alu tube 10" long.  I have yet to come across something I couldn't work into position with these 3.Have we all gone mad?
GMT+8, 2025-12-22 14:21 , Processed in 0.073101 second(s), 18 queries .
