42" Diameter fire pit
发表于 2021-9-1 00:19:30 | 显示全部楼层 |阅读模式
First we start by cuttingThen bend the sides and tack togetherThen we get the flux core outnext Attached Images --Gol'
Reply:Then we completely weld the sides to the baseThen bend some round stock around it Attached Images --Gol'
Reply:Then we cut and weld in some more pieces for the base.then make some legs and weld them onthen build a grilling surface Attached Images --Gol'
Reply:Final Result Attached Images --Gol'
Reply:great fire pit... now if I may ask... the table and the plasma... what is the diamension and system it used? any link...? Thx in advance...Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:Originally Posted by westlawn5554xgreat fire pit... now if I may ask... the table and the plasma... what is the diamension and system it used? any link...? Thx in advance...
Reply:Nice work. Like the manual ring roller. Do you cut the grilling surface on the plasma or just buy it prepunched?
Reply:Originally Posted by DSWNice work. Like the manual ring roller. Do you cut the grilling surface on the plasma or just buy it prepunched?
Reply:Excellent, Go1lum. Thanks for the pics.When you say we, does that mean that is not you in the pictures?
Reply:Originally Posted by Mark...Excellent, Go1lum. Thanks for the pics.When you say we, does that mean that is not you in the pictures?
GMT+8, 2025-12-22 14:21 , Processed in 0.089855 second(s), 18 queries .
