How did he make this joint?
发表于 2021-9-1 00:19:26 | 显示全部楼层 |阅读模式
Attached is a pic of two tubes welded at 90 degrees.Any idea how he got any strength to the joint? I don't think either tube had any metal removed for fitting. - Mike Attached Images
Reply:Waht kind of application? maybee the tube itself is the load bering part, and any weld is just there to keep it from moving around?  besides somhing like that, I might think an internal brace slid in.  Don't know.  but, not an expert.  Brain lee Sparkeee24
Reply:Originally Posted by Sparkeee24Waht kind of application? maybee the tube itself is the load bering part, and any weld is just there to keep it from moving around?  besides somhing like that, I might think an internal brace slid in.  Don't know.  but, not an expert.  Brain lee Sparkeee24
Reply:It looks like what he did was weld the inside of the tube and left enough to slide over the other tube and welded the outside of that. At least thats the only way I would know how to do it.
Reply:Originally Posted by landj815It looks like what he did was weld the inside of the tube and left enough to slide over the other tube and welded the outside of that. At least thats the only way I would know how to do it.
Reply:My question is "how are the two tubes that are crossing at 90^ to each other welded together?" - Mike
GMT+8, 2025-12-22 14:21 , Processed in 0.092908 second(s), 18 queries .
