cc/cv
发表于 2021-9-1 00:19:21 | 显示全部楼层 |阅读模式
Hear that alot...I beleive my ranger 8 is capable of one of those and has to do with hooking up a mig suitcase attachment like an LN 25 or something but could someone go into further detail of exactly what it means ?Lincoln Ranger 8Lincoln 140c MigLincoln Tombstone(doesn't everybody have one ?)Miller 200Diesel/Heavy Equipment MechanicLead Plant Mechanic Municipal Water
Reply:You stick or TIG on CC, constant current variable voltage, you run wire on CV, constant voltage, the current(amperage) will vary.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Thanks.Lincoln Ranger 8Lincoln 140c MigLincoln Tombstone(doesn't everybody have one ?)Miller 200Diesel/Heavy Equipment MechanicLead Plant Mechanic Municipal Water
GMT+8, 2025-12-22 14:26 , Processed in 0.458010 second(s), 18 queries .
