fcaw 0.68 need help
发表于 2021-9-1 00:19:20 | 显示全部楼层 |阅读模式
Hi i just tested for my wire feed cert i have a little undercut on my last pass over head on the cover and my teacher wants me to run a 1/8 bead next to it ,anything bigger then 1/8 and i will be laped over my cover plate to far ,  however i can not for the life of me get my bead under 1/4 inch in width every time i try it just is to high , ive tried different wire leangths different speed different amps but anything lower then what i run useal just comes out like crap , can you even run a bead under 1/4 with flux 0.68 ?  if anyone out there does and can help me with wire and amp settings to achieve this i would really love to hear from you , i know this test plate  passes as long as i can get that last pass down ,Last edited by sinner73; 02-16-2011 at 03:00 PM.
Reply:anyone ?
Reply:Maybe let it cool a little more before that last pass and you will not get that undercutting.Are stopping to wire brush the weldment before each pass?AWS certified welding inspectorAWS certified welder
Reply:Originally Posted by Donald BranscomMaybe let it cool a little more before that last pass and you will not get that undercutting.Are stopping to wire brush the weldment before each pass?
GMT+8, 2025-12-22 14:21 , Processed in 0.095694 second(s), 18 queries .
