Where to Buy Diodes
发表于 2021-9-1 00:19:18 | 显示全部楼层 |阅读模式
Where is the best place to buy welder diodes.  In my case Westinghouse with the threaded lug & braided lead coming out.
Reply:After you determine what voltageand current ratings you need, Search for rectifier diodes on Google.  Name brand is almost irrelevant, almost like buying regular gasoline, if the voltage and current specs meet or exceed your requirements I am sure that they are all pretty good.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:Does 275A or 306A,  -   300V sound right?
Reply:you might enter  "Welder rectifier diode" into google and follow up on what you find.There is always the possibility of contacting the welding machine manufacturer, they should be able to provide an exact replacement, for a price.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:X2 on Ebay.  There are always some "big boy" diodes on there.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:I have sold them on ebay, and i believe i have a few more on the shelf.........
Reply:+1 on Allied, and also Digi-key.-az-
Reply:Got my big diodes from Fair Radio lima oh. and ebay.
GMT+8, 2025-12-22 15:54 , Processed in 0.147903 second(s), 18 queries .
