remove gas tank?
发表于 2021-9-1 00:19:18 | 显示全部楼层 |阅读模式
hey folks did some welding on the underside of my truck bed, not thinking about the gas tank right next to me until i was all done. should i remove the gas tank if i am to weld underneath my truck again? there is a metal "wall" between the driveshaft and the plastic gas tank so nothing could hit the gas tank
Reply:Your hot electrode could punch right thru the plastic tank.Gas tank straps are usually badly rusted here
GMT+8, 2025-12-22 15:54 , Processed in 0.113421 second(s), 18 queries .
