air cylinder ideas
发表于 2021-9-1 00:19:15 | 显示全部楼层 |阅读模式
i was given a parker model 005.00cfmau34c33.00 cylinder by a freind.need a idea for project???200 psi
Reply:got a pic?If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:with the right weldment a really good can crusher ?insert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:Spud Gun?Me!
Reply:You can launch a golf ball a long way with a valve and the right size pipe. I used an e sized oxy cylinder it was great.  I carry guns because cops are too heavy. .. ..-.   -.-- --- ..-   - .... .. -. -.-   .... .- .-. -..   . -. --- ..- --. ....   -.-- --- ..-   -.-. .- -.   ..-. .. --. ..- .-. .   .- -. -.-- - .... .. -. --.   --- ..- -
Reply:Originally Posted by captdave2612You can launch a golf ball a long way with a valve and the right size pipe. I used an e sized oxy cylinder it was great.
Reply:Originally Posted by deadman1474My patato gun I can send them over half a mile. That's a hell of alot better then what I can do with a golf club.
Reply:here is size of cylinder 41 1/2long 5 1/2 wide 5 1 /2 high.1 " shaft the shaft extends 35 3/8 out.uses 200 psi has 1 5/8 thread on end of shaft .weigths about 50 lbs.
Reply:all measurement are in " thanks
Reply:Single or double action?  Be careful, it would make a really good "finger crusher"l.Hobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:I was thinking of a cylinder as an air tank...  Now I get it!  Is it single or double action?Me!
Reply:If it helps - The cylinder will have roughly 2000lbs push, when connected to 100psi shop air.
Reply:G.W. Shark repellant? "Smile you son-of-a-*****!"BOOYAH!  City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Chunk a pumpkin? City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-22 14:19 , Processed in 0.167107 second(s), 18 queries .
