5 inch weld neck flange
发表于 2021-9-1 00:19:14 | 显示全部楼层 |阅读模式
it's been a wile sense i posted any of my work so here is a 5"WNF i welded onleft hand to right then right hand to leftChuckASME Pressure Vessel welder
Reply:real nice beads..looks from the thickness  like the flange is rated for more pressure than the box its welded to..
Reply:thanks,150lb flange and the header is 100psi maxChuckASME Pressure Vessel welder
Reply:Nice job..You need a better camera or I need better glasses.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:i had my readers onso it must be the cameraChuckASME Pressure Vessel welder
GMT+8, 2025-12-22 14:39 , Processed in 0.068489 second(s), 18 queries .
