Bead critique please
发表于 2021-9-1 00:19:10 | 显示全部楼层 |阅读模式
I'm almost a one year Migger.This was FCAW actually, I don't remember the settings and stuff though...Sorry for the not-so-good picture, my camera is crap.
Reply:Not too bad.  fluxcore never comes out as pretty as you would like, but it looks nice and solid...The heat looks ok.  Looks like you change speed a bit early on, you started out moving kinda fast, then you slow down.  I'd just say to try and keep your speed a little more consistant and the overall appearance will improve.  Did you clean the metal before you did the bead or only after?Smithboy...if it ain't broke, you ain't tryin'.
Reply:I cleaned it before and after, this was may latest attempt at weaving.I got another project to do right now actually, I better get to it.  EDIT: Damn, clothes hanging up in the garage... Terrible day.Last edited by Rusty Toyota; 10-07-2005 at 10:45 PM.Student on a mission.   Be the best. If I can't be the best I sure as hell won't be the worst.
Reply:I'll echo smithboy. Bead doesn't look too bad for flux core. Flux core is a little faster freeze so you could slow down a little. Even travel speed will come later. With that comparitive thickness you could run a little hotter maybe.Just for reference, about half way between the two bolt holes, there is a teeny stretch where it is smoother and wet out better. You can even see where it wicked up and grabbed the base metal on the upper (red spots) side. That's kinda how I like mine to look. Nice pic.
GMT+8, 2025-12-22 17:45 , Processed in 0.102408 second(s), 18 queries .
