Watcha macallit
发表于 2021-9-1 00:19:06 | 显示全部楼层 |阅读模式
Can you guess what these are?  A hint: they are all stainless.   Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Oh yeah... It's 1" s.s. pipe connected to perforated gage s.s.(approx 16ga with 1/8" holes running at 600 big ones per sheet).  On a side note, I worked for a place with a cnc punch that made their own sheets.  When they started punching some of the thicker s.s. materials, you could feel your teeth coming loose.  And I was a good 50' away from the machines.Common sense in an uncommon degree is what the world calls wisdom.
Reply:I don't know the answer, but I still like to guess   Are they used in the wine making industry?-Ryan McEachern
Reply:Is that the new satellite system so E.T. can finally phone home?I am what I am, Deal with it!If necessity is the Mother of Invention, I must be the Father of Desperation!
Reply:Yes, they have something to do with wine.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Some sort of a stick to manually smash grapes?
Reply:I was going to say new fangled butter churn, but that doesn't have anything to do with wine, so yeah looks like a grape smasher, or maybe a filter for when they empty the tanks.
Reply:"strainer"?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Look like they are for stirring the wine to help in the separation of the skin form the grapes
Reply:bird stands?Don't talk about it, Just do it!
Reply:I've got it water balloon catcher all the water none of the rubber lol350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:I was gonna say a microphone stand for people who talk out of both sides of their mouth!!
Reply:I am leaning toward a really nice rack to hang my welding jacket on
Reply:An udometer or rain gauge; for CaliforniaHobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:A grape mash press.
Reply:Originally Posted by Vicoorbird stands?
Reply:Originally Posted by BrainfarthOh yeah... It's 1" s.s. pipe connected to perforated gage s.s.(approx 16ga with 1/8" holes running at 600 big ones per sheet).  On a side note, I worked for a place with a cnc punch that made their own sheets.  When they started punching some of the thicker s.s. materials, you could feel your teeth coming loose.  And I was a good 50' away from the machines.
Reply:Pretty close guesses.   While the grapes are breaking down in open top tanks, they form a crust on the top which has to be broken up twice a day.  So the longer ones are for taller tanks with an extra handle for better stability.All I know is that after 5000 holes being punched in the stainless, you started to resent the machines.Common sense in an uncommon degree is what the world calls wisdom.
Reply:I have no clue what the purpose of the perforated cone on the end is but, it looks like this dude might be using one of those.edit:  HaHa JINX! Attached Images
Reply:Haha... Good timing. And right on the money.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by TSORI have no clue what the purpose of the perforated cone on the end is but, it looks like this dude might be using one of those.edit:  HaHa JINX!
Reply:Originally Posted by Road WarriorI was gonna say a microphone stand for people who talk out of both sides of their mouth!!
Reply:The actual process is called punching the cap. The reason the grapes, and grape skins float to the surface is because of the process of carbonic maceration.
Reply:Yeah I figured some people in this thread would want to know the purpose of those cap punchers.  Ive been making wine and beer for over 7+ years, and this was right up my alley.  Glad you liked the info.
Reply:Zap now I understand where the thingamajig you were working on fits!
GMT+8, 2025-12-22 15:56 , Processed in 0.088821 second(s), 18 queries .
