how to weld on a car
发表于 2021-9-1 00:18:53 | 显示全部楼层 |阅读模式
lincoln 140 mig welder using .035 flux core wire im new to welding i have never welded on a car i think all i need to do is disconnect the the pos and neg battery terminals and keep the ground clap as close to ware im making the weld as possible. is that all i need to do??
Reply:beyond that, don't weld on anything but body panels, with your implied inexperience. and i would highly recommend solid wire with gas for body work.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:thank you for the good advice p,s, im going to be welding a exhaust bracket back on
Reply:Be sure to clean the ground and the weld area. You don't want the arc going anywhere but the weld area.Millermatic 200Hobart Handler 120Victor O/A & Ramco BandsawLincoln 225 ACSnapOn AD HoodMiller XMT304/22AHypertherm Powermax 1650 G3Lincoln Idealarc DC600 w/Extreme 12 VSMiller Digital Elite "Joker"
GMT+8, 2025-12-22 15:56 , Processed in 0.092961 second(s), 18 queries .
