Conversion kit for century 125gl
发表于 2021-9-1 00:18:50 | 显示全部楼层 |阅读模式
Is there a kit to convert a century 125gl to gas? There is a fitting and line on the machine.FrizzyUncle Frizzy
Reply:I think so.  At least I know I have seen one of these with a mig setup for sale on ebay.Smithboy...if it ain't broke, you ain't tryin'.
Reply:If there's a fitting for it, just get yourself a Victor AF150 regulator and hose from Cyberweld for about $50 and that should do it.  That's the regulator I see most often on 120VAC machines.  It's a flow-gauge instead of a flow meter, but it works well enough for occasional use.-Heath
Reply:I guess I thougt you meant that you didnt even have a solenoid for the gas....If you have the valve and solenoid already, all you need is the regulator and hose, like Halbritt says...and a bottle of gas and solid wire.Smithboy...if it ain't broke, you ain't tryin'.
Reply:I appreciate the info, guys!  FrizzyUncle Frizzy
GMT+8, 2025-12-22 15:54 , Processed in 0.089326 second(s), 18 queries .
