life guard chair stand
发表于 2021-9-1 00:18:45 | 显示全部楼层 |阅读模式
i was asked to buid this stand for a life guard chair .the tube is 4"SQ 1/8 wall the base and top plate are 5/8 thick x8"widethe base is 16"long top8" all carbon steel.(yes i know stainless would look better and last longer) i was told to use what i usedChuckASME Pressure Vessel welder
Reply:moreChuckASME Pressure Vessel welder
Reply:last oneChuckASME Pressure Vessel welder
Reply:Whats that little tube do?
Reply:holds the steps and hand railChuckASME Pressure Vessel welder
Reply:Looks sweet! Just a quick question,How do you hold up the square tubing while you are welding?Probably a dumb one question!
Reply:it was layed down to tack up then stood up and clamped to my bench for weldingChuckASME Pressure Vessel welder
Reply:Where is that going? Metro?Looks good but it doesn't look much like a pressure vessle
Reply:Originally Posted by tanky321Looks sweet! Just a quick question,How do you hold up the square tubing while you are welding?Probably a dumb one question!
GMT+8, 2025-12-22 16:29 , Processed in 0.096920 second(s), 18 queries .
