The Grille..
发表于 2021-9-1 00:18:45 | 显示全部楼层 |阅读模式
I have had about a dozen P/M'S about the grille and how it was made..First off I did NOT make this I bought it..Mrs zap says it came from Harbor Freight..Whatever..Here are the pics of the grille and what you need to make one..Either aluminum or steel rims will work here..On with the pics..Complete assy..Lid..Note the stock car baffle for the hole..Parts..Small grate for the charcoal fits on the inside step..I know it's hard to see the step..The bottom is a piece of 1/8" sheet cut to fit and mig welded..Next!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:On to the stand..It's nothing more than a round ring I turned undersize one day and with the addition of some 3/8" square stock welded to the outside then the correct size was made to fit the rim with a little "Rounding of the corners..Other than that just some 1/8" stock to hold the legs together at the bottom of the base..Now go out and make one!Be sure to post pics.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Opps, my bad for asking the original question that probably started this. Serves you right for posting neat things however and doing great work. Everyone just assumes you did it. Thanks BTW for taking the time and showing how it was made.
Reply:Did you say MIG welded?  Fire!, Fire! Oh wait, that's my torch...Lincoln PT-225 TIGLincoln 175 MIG
GMT+8, 2025-12-22 16:28 , Processed in 0.068873 second(s), 18 queries .
