Pictures from work
发表于 2021-9-1 00:18:44 | 显示全部楼层 |阅读模式
I had to weld the end of a vessel on.  It's all 7018 on the inside, then it was back gouged and the sub arc welders welded the outter seam.Last week I was welding nozzles, and here is how we left it two weeks ago. I came into work tuesday and they had the head fit on.  The vessel walls are 7/8" thick.time to make the blue light!These are the first and second fill passes.  the first was done with 3/16" 7018 at 230 amps.  The second was done with 1/4" 7018 at 330 amps.  It's all flat rolled, so it's not rocket science!Time to cap!  3/16" rod at 336 amps, 30% arc force.  It's a two pass cap, here I was just starting the second pass.I'll try and get some more pictures on monday, they were sub-arcing it on thursday, so I never had the opportunity to take pictures of the cap cleaned up and surrounding area de-spattered! Thanks for looking!
Reply:That is a big milk bottle... nice work... Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
GMT+8, 2025-12-22 16:31 , Processed in 0.068055 second(s), 18 queries .
