Fuel Cell Parts
发表于 2021-9-1 00:18:43 | 显示全部楼层 |阅读模式
Wondering if some of you fuel tank builders could find some parts for me.  Ive been looking for aluminum weld on nipples for 3/8 hose and weld on air tight filler caps that either mount flush or very low.I have found barbed nipples but they were in france and all the fillers I find are bolt on or to tall or vented.And since this is in the projects section I will post it when I get started.Have we all gone mad?
Reply:www.racepartsolutions.comE-bay will have the alum weld filler caps as well. They are like 20.00http://cgi.ebay.com/ebaymotors/alumi...spagenameZWDVWT.J.Last edited by TJS; 05-27-2008 at 10:50 PM.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Perfect, for some reason it never clicked to look on ebay.I decided im just going with -6AN bungs on the tank so its easier to modify in the future if I need to.Have we all gone mad?
GMT+8, 2025-12-22 16:31 , Processed in 0.098340 second(s), 18 queries .
