can i weld this up?
发表于 2021-9-1 00:18:42 | 显示全部楼层 |阅读模式
this broke on day when my mum was mowing dont no why but can i weld it with these rods..these are the rodshttp://i306.photobucket.com/albums/n...0Image0393.jpg[url=]
[img][/img]
[/url]http://i306.photobucket.com/albums/n...0Image0398.jpg
Reply:http://i306.photobucket.com/albums/n...0Image0394.jpg
Reply:I think the wheel is cast alum or an alloy. If it is the answer is no. Take a magnet and see if the wheel is magnetic. If it is not then no those rods will not work.
Reply:yer it is alloy ok then look like ill have to buy one then.
Reply:You have nothing to lose, at this point.  The wheel is likely cast aluminum, but that doesn't mean welding it is impossible.  You'll burn out that seal, if you can't remove it and put it back in afterwards.
Reply:your not going to weld on that, doesnt matter what its made of. junk is junk.
GMT+8, 2025-12-22 16:30 , Processed in 0.131297 second(s), 18 queries .
