My biggest project with a H187
发表于 2021-9-1 00:18:42 | 显示全部楼层 |阅读模式
Hey ganghere are sonme pics of my biggest project using my H187, it is a smoker/pig roaster made mostly from recycled metal, it started with an old water tank from a concrete truck, and lots of metal from the scrap yard.Not much detail of the weld beads however, enjoy:In the garage:Building the fire box:The fire box:Divider plate:Dry fitting the reverse flow stack and door safety holdup:Done:First sausages:First pig roast, 70 lbs:
Reply:sweet ,now I'm hungryChuckASME Pressure Vessel welder
Reply:Now THAT is a smoker to be proud of...excellent job! I have to add that one to the project list as well. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:ThanksYeah, I'm very proud of it. I can't believe I ended up building such a monster  I suppose in this case bigger is better  Here's another view:
Reply:Portable ready to go partier rig. Thats a nice build. Good job, nice smoke stack adjuster,clean all away around.Good judgement comes from experience.Experience comes from bad judgement.
GMT+8, 2025-12-22 16:28 , Processed in 0.222308 second(s), 18 queries .
