tungsten questions
发表于 2021-9-1 00:18:41 | 显示全部楼层 |阅读模式
The tunsgten with the red stripe is slightly radioactive so what extra care should be taken when grinding the point?  Radioactive can't be good so should I just ditch the 3 electrodes I have and get some other ones?  I read up a bit on http://www.aglevtech.com/About_Tungsten_Electrodes.html.  I am new to tig so may be doing quite a bit of sharpening for a while.  I am working with mild steel at 1/8 and under for now.  Thanks, ChadLast edited by chadr; 11-15-2005 at 12:19 AM.
Reply:I wouldn't be too worried about it. You're doing more harm to your body if you weld without using a respirator....
Reply:We have a good article on our site about grinding tungsten(tip geometry and the like)http://www.arc-zone.com/catalog/web_....html&cart_id=Also, if you're concerned about safety, http://aws.org/technical/facts/Article No. 27 has info on thoriated tungsten electrodes.We generally recommend that if you don't have to use, that is to say its not in a specification, then why bother when there are safer alternatives available.  Hope that Helps!--Carmen Electrode   , www.Arc-Zone.com
GMT+8, 2025-12-22 16:27 , Processed in 0.066303 second(s), 18 queries .
