need some input
发表于 2021-9-1 00:18:33 | 显示全部楼层 |阅读模式
here are my latest vert up with .045 er70-s3 wire 19.5 V not shure of the ampthe wire speed was just under 17 ipm and im useing argon/c02 80/20any input on what i could do to make them better other than just keep practing till i get it right Attached Images
Reply:Looks to me your well on your way.David
Reply:thank s that is four lunch hours of welding to get to that point  i think i just need to get the weave down to get it smother but I'm not surechuck
Reply:can you cut a few of those in half?  I'm curious about penetration.  Looks beautiful for 4 hours of practice though.  Good job   Keep up the good work.  The practice is making it come along very nicely.  Brian Lee  Sparkeee24
Reply:Looks good , can tell volts & amps are set good very little splatter .You have a little undercut , Try tightning up your beads when travelinguphill and should solve problem
Reply:thanks i not use to this short circuit welding most of the pipe welding i've donehas been spray transfer so i never had to weld vert up or deal with splatter  but im trying cant seam to get rid of the under cut  and dont even get me started on the open joint of the root  any ways thanks for the kind wordschuck
Reply:If your having trouble with undercut try holding on the sides a little longer and make the weave tighter. I haven't done any mig for year's but from memory that swhat I used to do.Stephen
Reply:Have you tried .035? .045 can be a handfull. Open root pipe? Run downhand with a keyhole.
Reply:no .035 is not used in my shop ,and i did learn from a welder at miller thatim not going to get a much better bead with the .045 so i turned in what i got and hope it will pass i got .035 at home wen i get time here im going to try it on my sp-135 and see if i cando better , next up is over head  just to see if i can chuck
Reply:this weld was done with my sp-135 plus uesing .035 fluxcore on 3/8 platechuck Attached Images
GMT+8, 2025-12-22 16:30 , Processed in 0.066721 second(s), 18 queries .
