1inch plate welding
发表于 2021-9-1 00:18:29 | 显示全部楼层 |阅读模式
Hello I'm new here, I have been welding for many years but mostly 1/2" or less and recently started getting into heavy plate I have been doing it with a delta weld450 with .045 wire dose any one have any tips for me?
Reply:I'd use bigger wire. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Get yourself some Lincoln 1/16 71 Elite. You will like that for all your plate work after you try it.
Reply:spray mig
Reply:5/32 6010.Have we all gone mad?
Reply:Originally Posted by sn0border885/32 6010.
Reply:Hello 450guy,If you’re welding flat or overhead fillet welds or flat groove welds, indoors (no wind) try Hobart Quatum  Arc D2 wire with 95/5 shield gas. (95%Argon/5%Oxygen) or 98/2 (Argon/CO2) For  .045 try 25.5 to 26.5 volts, I can’t be spot on with the wire speed, we use old POS LN-7 feeders, best I can say is adjust the wire speed so you have a nice, well defined arc cone and a very slight crackling sound. Preheat the metal a little, maybe 200 degrees surface temp, depending on the size of the parts. CLEAN ALL THE SCALE FROM THE WELD ZONE.Yes, grind the weld zones to bright metal. Believe me, it’s not as bad as it sounds. Lots of guys cry about grinding, but if you leave your purse and makeup bag in the car  , get a good 9” grinder, a decent type 28 stone, and just get it done, it’s over before you know it.I found a picture to post with this. It is of a small weldment, the horizontal plate is ½” A36 (the one that’s edge on) and the vertical plate is 1”T1. It is welded with Hobart Quantum Arc D2 .045 ER80 S6 with 95/5 shield gas. The scale was ground from the weld zones before welding, after welding no sanding or scraping, just cleaned with a cup brush on a 4-1/2” grinder.   As a post script note; I did not intend to offend any of the talented young women on this forum with the above purse comment……. just the girlie men  Attached ImagesWill
GMT+8, 2025-12-22 16:29 , Processed in 0.150797 second(s), 18 queries .
