How do I fix this gas line?
发表于 2021-9-1 00:18:27 | 显示全部楼层 |阅读模式
Bought a tig torch from Harbor frieght, last one they had. It was used and the end of the hose is cut. Can I get a fitting to repair it without leaking or do I need to replace the entire hose?More pics here:http://weldingweb.com/vbb/showthread.php?t=51359Thanks.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Best WayDownload the manual for the torchLocate the hose on the parts list Order a new hoseI offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:It's a harbor freight torch, and it doesn't show up on their site. I've been searching that way for awhile now and come up empty handed.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:On my HF TIG torch, it looked like they wrapped it in vinyl tape (read: electrical tape).  If you buy the HF regulator, it will have a hose barb to 9/16-18F adapter that will match the regulators 9/16-18M discharge.  The other fitting that is common on regulator discharges is 5/8-18F, so you'll need an adapter for that.
Reply:I already have a regulator. I'm trying to avoid buying another.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Well then you're going to need a 3/16" hose barb to whatever will fit your regulator.  A picture or model number of the regulator would allow me to tell you the other side of the adapter.
Reply:Ok. A barb fitting and adapter that will be perfect. My main concern though is can I use just a barb fitting or do I need a special fitting? i.e. Will a barb fitting leak gas?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:On mine, I was lucky to get the barb in the hose at all.  It's a pretty tight fit.  If you need more security, you can put a hose clamp on it.http://store.weldingdepot.com/cgi/we...ot/HC-50x.html
Reply:And it doesn't leak?Did you use a male or female barb fitting?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:better than a hose clamp is this tool---clamp-tite . you can buy it here --http://www.bluewater-marine-rv.com/html/clamptite_tool.html  . use thin stainless or monel wire to make the clamp.
Reply:Looking for something locally so I can just go out and get it and if it doesn't work I can just go return it.THanks for the idea though.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
GMT+8, 2025-12-22 16:29 , Processed in 0.102017 second(s), 18 queries .
