Miller syncrowave 250 troubleshooting
发表于 2021-9-1 00:18:27 | 显示全部楼层 |阅读模式
Hi GuysI have the circuit board out of my syncrowave 250 and I need the values for the 4 transformers marked T1 T2 T3 T4 respectfully ..and would anyone know where I can purchase one of them..there is just enough surface rust to make reading the values impossible.and I don't see them on the miller diagram pdf files, any help would be appreciated as I have a job to do and am under the gun  Thanks Tony
Reply:There's more than one board design for that machine.  I had an early one and when the board failed some modifications were required to install the replacement.  Make sure you're getting the numbers from the same series.-jimDynasty 300DXSmith He/Ar gas mixerMM350PHobart Handler 120Smith LW7, MW5, AW1A
Reply:There's more than one board design for that machine.  I had an early one (sorry, I sold it several years ago) and when the board failed some modifications were required to install the replacement.  Make sure you're getting the numbers from the same series.-jimDynasty 300DXSmith He/Ar gas mixerMM350PHobart Handler 120Smith LW7, MW5, AW1A
Reply:thanks JimBoard number is 132 887  and has  a kA -5 sticker up in the  corner above the row of transformers.believe it was made in the early 90s.. serial number starts with JK..anybody know where I can get the numbers off of the transformers..or can download a service manual for that series..Thanks agian Tony
GMT+8, 2025-12-22 16:28 , Processed in 0.087619 second(s), 18 queries .
