Small Metal Storage Rack
发表于 2021-9-1 00:18:26 | 显示全部楼层 |阅读模式
Here's a simple metal storage rack I build out of old used material I had laying around.  Its got a place in the back to hold sheets and large pieces, a 3 armed rack to hole tubing and pipe, and a bin on bottom to hold all my small cutoff.  I plan on making some dividers to separate the bin so I can look through it easier.  Heres a few photos. Attached ImagesOnly two defining forces have ever offered to die for you, Jesus Christ and the American G. I. One died for your soul, the other for your freedom.
Reply:Not a bad looking cart. It should do you pretty good as long as you have a place for the longer stuff.Nice Job.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:nice cart looks good and work like its made tooChuckASME Pressure Vessel welder
GMT+8, 2025-12-22 16:28 , Processed in 0.064967 second(s), 18 queries .
