What to do w/old aircompressor
发表于 2021-9-1 00:18:25 | 显示全部楼层 |阅读模式
I got this from a neighbor, it had sat outside his house over six months. He said the guy that gave it to him said it ran but my neighbor never did anything with it. After a half hour messing with it to get it running it started up but once at 60psi it blew a hole at a welded seam. I know once that happens theres no since in welding it since their will be more and the failure at higher pressures can be more dangerous. So my question is what to make out of it. Maybe a muffler type man for the garden? Attached Images It's not what you can buy, it's what you can build that matters
Reply:It builds pressure, so mechanically its fine. Might make a nice booster for an existing compressor if you plumb it to the existing one. Keep an eye out on craigs list and so on, you may get lucky and find a dead machine with a good tank. I had one laying around for the longest time that I used as a portable spare tank, I have no idea where it is now.The pump looks like a nice oiled cast iron pump. you might get a couple of bucks just for the motor and pump on craigs list.
Reply:Yeah, it should be fine with a new tank.Normally the motor or pump blows way before the tank, so it shouldn't be too much work to find an unwanted tank somewhere.The Welder Shop has great deals and reviews on Hobart, Miller and Lincoln Welders.
Reply:Keep a lookout for a compressor with a good tank and burned out motor/compressor, yup I like that idea! With the old tank, you could make a drum. City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:nice tunes, tanglediver
Reply:BBQ/smoker maybe? instead of a muffler-MAN, why not a muffler PIG? a small cow maybe? just something different that you don;t see everyday.Later,Andy
Reply:I like the BBQ smoker idea for the tank.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:I've been making and selling BBQ pits "Tailgaters" out of those tanks for years. They come in real handy when hunting, fishing or wheeling..
Reply:I have the same one, and need new reeds for the compressor.  Anybody know where to get them or do you want to part with the headed.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Surplus Center sells air tanks in several sizes, complete with wheels and mounting bracket.
GMT+8, 2025-12-22 16:30 , Processed in 0.093897 second(s), 18 queries .
