Recent Work
发表于 2021-9-1 00:18:24 | 显示全部楼层 |阅读模式
Been working on this truck for a couple weeks. Thought I would share.Last edited by Twisted Minis; 05-24-2008 at 02:14 PM.Lincoln PowerMIG 215XTLincoln Precision TIG 225Hypertherm 300
Reply:I just need to build a brake line mount tomorrow, then pull it apart to paint everything.Lincoln PowerMIG 215XTLincoln Precision TIG 225Hypertherm 300
Reply:looks good where abouts in ca. are you?millermatic 210miller 375 xtreamlinde power supply hda 200 tigcentury 110 flux corelincoln buzz boxlet the work speak for itself i do!!!check mine out at http://www.eyepoppincustoms.com
Reply:looks pretty good to me.  If it were me if add some fish plates to where you notched the frame for the rear end.  Is it raining up in windsor today?  its raining down here in the bay area...
Reply:Originally Posted by eyepoppin customslooks good where abouts in ca. are you?
Reply:sounds good
Reply:Originally Posted by Twisted MinisThe North end.
Reply:I think he means California - not Canada - I'm about 20 mins outside Windsor, OntFire!, Fire! Oh wait, that's my torch...Lincoln PT-225 TIGLincoln 175 MIG
Reply:Windsor is near Santa Rosa, California, & that's near me, I live in the Napa Valley, (Calif.)Last edited by Roy Hodges; 05-25-2008 at 12:03 AM.Reason: spelling[SIZE="5"Yardbird"
Reply:alright, another northern californian wooooohoooooo
Reply:Yea I'm in California, not Canada. I've heard that before, seeing as there is a Windsor in both places.Lincoln PowerMIG 215XTLincoln Precision TIG 225Hypertherm 300
Reply:That is nice worx... maybe you should pimp my ride...Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:my bad, the work looks realy good, sorry about the mix up. you ever get out to the mid west for any car shows like ITB in indy.millermatic 210miller 375 xtreamlinde power supply hda 200 tigcentury 110 flux corelincoln buzz boxlet the work speak for itself i do!!!check mine out at http://www.eyepoppincustoms.com
Reply:Twisted Minis,very cool both on the fab and welding .were do you get the bushings?are thy rubber or polyurethane?ChuckASME Pressure Vessel welder
Reply:Originally Posted by eyepoppin customsmy bad, the work looks realy good, sorry about the mix up. you ever get out to the mid west for any car shows like ITB in indy.
Reply:impressive stuff
Reply:Thanks tapwelder.Brake line done.Lincoln PowerMIG 215XTLincoln Precision TIG 225Hypertherm 300
Reply:It all looks good to me. Looks like a long slow job though. Good luck and hope you don't have any problems you can work through.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:Here it is with some paint.Lincoln PowerMIG 215XTLincoln Precision TIG 225Hypertherm 300
Reply:And new Toyota control arms for the Toyota clip going under it.Lincoln PowerMIG 215XTLincoln Precision TIG 225Hypertherm 300
Reply:Very cool. This would make a nice step by step build up article. Great pics.
Reply:I'm no suspension expert by any means but shouldn't there be a panhard bar? or something to limit the side-to-side movement of that axle?  It looks like there will be a lot of leverage on those joints the way it sits now?
Reply:Originally Posted by AcemanI'm no suspension expert by any means but shouldn't there be a panhard bar? or something to limit the side-to-side movement of that axle?  It looks like there will be a lot of leverage on those joints the way it sits now?
Reply:Thanks for the explanation Twisted.
Reply:Twisted Minis againe nice work ,thanks for the info on the bushings i made rear lower contorl arms for my 2006 stang and now im thinking about a watts linkChuckASME Pressure Vessel welder
GMT+8, 2025-12-22 16:30 , Processed in 0.254555 second(s), 18 queries .
